99 jetta III rear grinding noise
Old Nov 16, 2008 | 11:12 AM
acwangelin's Avatar
Default 99 jetta III rear grinding noise
Hello everyone, I was hoping someone could offer me some advice on a problem I have been having. I have a 99 jetta III that is making a grinding/ rubbing noise at the right rear wheel. This noise occurs the most when I have a passenger sitting over the rear wheel and generally goes away after a couple of blocks until the vehicle comes to a stop. When I start driving again it makes the noise again. I just replaced the struts (not the springs) so I was thinking it could possibly be the wheel bearing? Just looking for some advise. Thanks.
Old Nov 16, 2008 | 12:01 PM
racerx002's Avatar
Default RE: 99 jetta III rear grinding noise
Did you replace the strut mounts while you were up?
Old Nov 16, 2008 | 01:02 PM
Jrailer's Avatar
ya it might be a bearing
Old Nov 16, 2008 | 03:06 PM
acwangelin's Avatar
I did not replace the strut mounts while I was at it. Do you think that could be it. I would like to avoid replacing the wheel bearing if I can, would like to leave that project as a last resort.
Also, I did a quick check for parts on 'autopartswarehouse.com' (its where I seem to be able to find everything I need) and the only strut mounts I could find there were for the front. Are they interchangeable?
elongride
Jun 24, 2010 11:38 AM
jhansen704
Mar 5, 2010 05:42 PM
zak1234
Apr 27, 2009 07:01 PM
kevgreek
Mar 2, 2008 12:19 PM
jbag
Sep 3, 2007 11:08 PM
