99.5 Engine Speed (Crank) Sensor
Old Jul 28, 2007 | 12:47 PM
connor6141's Avatar
Default 99.5 Engine Speed (Crank) Sensor
Well.......this is my second related post.........but I have more specifics. I replaced a failing Engine speed (Crank) sensor on my 2.0 Jetta which corrected the problem, but aweek later, the car wouldn't start. After running through all the electrical diagnostics, I found that the replacement failed as well. The replacement I used was an aftermarket at 1/2 the price....so I'm skeptical. I'm also wondering if the ECM could be shorting out the crank sensor.
Anyone have experience with aftermarket sensors..........or can comment on whether the ECM could be screwing up the sensor?.
Thanks Much.
Old Jul 28, 2007 | 04:47 PM
joenewton07's Avatar
Default RE: 99.5 Engine Speed (Crank) Sensor
if you dont go oem, theres a good chance it'll fail. always go oem
maya2.0
Jun 5, 2012 07:55 AM
trappurr
Jun 12, 2011 04:29 PM
cfdad05
Nov 13, 2010 09:17 PM
4My2000Jetta
Apr 17, 2008 09:22 PM
sefiroh
Jan 8, 2008 09:11 AM
