-   -   95 jetta 2.0 couple of problems i have (https://volkswagenforum.com/forum/volkswagen-jetta-bora-19/95-jetta-2-0-couple-problems-i-have-12672/)
stock95jetta Aug 7, 2009 04:52 PM
hi, everybody any help would help thanks
i have 95 jetta 2.0 i have the oil pressure light on blinking all the time
i looked at the Clinton manual this is what it said
low oil lever it has the right amount of oil
idle rpm below spec it idles at 800-900 rpms which is right
worning engine bearing or oil pump i still have to chk the pump and i dont think it is the bearing it has 67,xxx miles but ill check that also
oil pick-up strainer clogged i still need to check that also
oil pressure relief valve defective where is this at?
Is there any think im missing if so plz mention it on this thread any help plz
plus where can i check to see the the oil presurre with a gauge?
also how can i adjust the clutch cable
thanks
bernardo
