-   -   94 jetta ELECTRICAL PROBLEMS HELP (https://volkswagenforum.com/forum/volkswagen-jetta-bora-19/94-jetta-electrical-problems-help-5252/)
jetta16x Mar 18, 2008 08:56 AM
so i recently purchased a 94 jetta. wen i went to start it it just wouldnt start, and i realized the fuel pump wuznt relaying on key up. so i checked the fus and it wuz blowen i put a new one in and it ran for like 5 min before i poped again, i put another one and it poped rite away. i checked all the wireing and there isnt a short any where. after doing all that i put a new fuse in and turned the key so it just just before it would start and i accidently hit the blinker and the fuel pump went whacko. and it poped the fuse. it does the same thing with the wind shield wiper. someone plz help me cuz i dont wanna have to spend 450 dollars on a fuel pump and have it b something simple and cheap.
bagel Mar 18, 2008 05:24 PM
RE: 94 jetta ELECTRICAL PROBLEMS HELP
sounds like a definite wiring problem. Was there a sound system in there beofre you bought it?? Usually home installations are #1 for wiring problems.
jetta16x Mar 20, 2008 06:25 PM
yea it did and when i hooked it back up it sounded like every speaker was blowen. then i hooked up a different one and it changed it and it sounded good. i found the wires that are melted and it is the black with yellow stripe n it goes to the ingnition switch.
jetta16x Mar 20, 2008 07:48 PM
after i did that the headlights came on annd it ran fine but then one of the wires in the group of 4 started 2 short out and smoke. idk wut is goin on with this. im getting so frusterated.
bagel Mar 21, 2008 09:35 AM
told ya....You HAVE to re-run every wire that is fried. My mustang did the same thing and caught fire underneath my middle console. Scary as hell when you driving down the road and a fire happens!! Anyway re-run all the fried wires or it will get worse.
