-   -   3 bolts turbo/manifold help .03,wolfsburg-Turbo 1.8T (https://volkswagenforum.com/forum/volkswagen-jetta-bora-19/3-bolts-turbo-manifold-help-03-wolfsburg-turbo-1-8t-36230/)
Ramza Feb 2, 2014 10:17 AM
Hi all,
I'm New to volkswagen period,
Bought a used 2003 Jetta Wolfsburg editon turbo 1.8 5 speed nightmare.
Many things happen but I am now on a manifold problem.
I had air leaks like crazy . took off manifold to the exhaust and found no gasket and the 3 bolts on top that connect manifold to turbo/down pipe (sorry do not know proper name) were loose dew to all 3 bolts don't belong their. 1 bolt short other 2 blots were to big and someone tried to force thread but only the tip was in.
Can some one please help me with the size and length to this bolt .
Volkswagen wants 87 $:eek: for so-called special bolts:confused: which is BS rip-off
hiddenramza's's Library | Photobucket
I'm very sorry I tried many times to post the pics here but I am having trouble with the url's I get for forums. so this is a direct link to my pics hope it works and thanks in advance for any help I get even ifs a pointer in the right direction
Ramza Feb 2, 2014 12:38 PM
http://i1221.photobucket.com/albums/...rcoolerpic.jpg
Number 16
jmdortch48 Feb 2, 2014 04:46 PM
Volkswagen Jetta IV 1.8T Engine Turbocharger ES#2627536 Turbo Mounting Bolt - Priced Each - 058145540
If all you need is the 3 mounting bolts, there you go. $9 a piece. If you need a full hardware kit (studs, bolts, nuts, washers, gaskets) for the turbo on both ends (manifold and downpipe) they have a full kit on that site as well for less than what VW was trying to sell you those "special bolts" for.
Ramza Feb 3, 2014 07:53 AM
Life saver bro ty :D Just needed the 3 bolts size and length.
Thanks to that link my task is done.
My car has many problems after I do some research and see if I can fix them. If I get stuck should I build of this thread and give a new title or start a new ?
