2010 Volkswagen Jetta Issue
Welcome to the forum.
It sounds like the immobilizer is enabled and the light should be on in the dash. It will only run for 1 second each time you start it.
What have you been doing to it?
There isn't much you can do with a 2010 Passat as its a dealer fix only. You could try and disconnect both battery leads and hold them together to discharge any capacitors in the system. Make sure the battery is charged up, reconnect the battery leads and try it again.
No 2010 models have immo 5 so you still need to have a dealer fix the problem if the immobilizer lamp is flashing on the dash.
VW and Audi key, remote, and immobilizer FAQ and troubleshooting
Post moved to the Jetta section.
bimmernupe
Oct 19, 2010 11:04 PM
dave@nedustoff.com
Feb 28, 2010 07:57 PM
andrew1984
Aug 19, 2009 03:29 PM
