2009 Jetta. I need the installation manual radiator.
Old Mar 25, 2011 | 03:14 AM
gostin's Avatar
Default 2009 Jetta. I need the installation manual radiator.
Help. I need the installation manual radiator. I need a picture. Drawing. 2009 Jetta.
Old Apr 4, 2011 | 03:37 PM
smar969905's Avatar
Member
you need a drawing for the installation of a radiator for a 2009 jetta? radiators on cars are almost all the same, 4 hoses - 2 big to the motor & 2 small to heater coil, power for fan(s) that is/are attached to radiator, and 2 bolts toward the top of radiator that keep supports on it so it stays in place. on the bottom of the radiator, it has feet that go into rubber isolators so it can move a little.
assuming this is to replace the radiator:
drain coolant system from bottom of radiator, and open overflow cap to allow air in. make sure to catch the coolant coming out as it attracts animals and is poisonous to them. several autoparts stores will recycled used coolant for free. remove the power harness from the fan(s). disconnect hoses from radiator. remove top supports on radiator. lift radiator straight up to take it out. using screwdriver, probably #2 philips head, remove the screws holding the fan(s) on. put fan(s) onto new radiator using same screws. slide new radiator into place, putting the feet into the isolators. put top supports back in, but leave a little loose. reattach 4 hoses. plug power harness back into fan(s). tighten top supports. refill radiator first, then add coolant to overflow/reservoir. start car, and run it for about 10 minutes adding more coolant as necessary.
jetta96gls
Oct 23, 2009 06:56 AM
clash0901
Aug 14, 2008 09:02 PM
jakejetta
Sep 1, 2007 03:20 AM
sfs63
Sep 3, 2006 01:00 PM
sfs63
Sep 3, 2006 12:57 PM
