2005 1/2 Jetta - Noise Question
Old Oct 18, 2005 | 01:31 PM
ceskow's Avatar
Default 2005 1/2 Jetta - Noise Question
Does anyone have a new Jetta, manaul transmission, that while changing gears under "stress" faster acceleration, etc, that sounds like a rock or large object is hitting the underbody? If so, have you had it checked and found out what it is?
Old Oct 20, 2005 | 04:12 PM
patrick's Avatar
Administrator
Default RE: 2005 1/2 Jetta - Noise Question
hmm..that sounds bad..i would get it looked at..find a shop with no rack fee, and have them look at it for you.
Old Oct 21, 2005 | 12:16 AM
Jsd's Avatar
Jsd
you sure you're not just grinding the gears?
Old Nov 1, 2005 | 03:30 PM
patrick's Avatar
Administrator
hmm..good point.
Old Nov 8, 2005 | 11:41 AM
jmwone's Avatar
I also have experienced the same noise. I thought it was back fire but the dealer said it would code if it did. Ultimately they had no answer for the noise. I also had them check out a rattle that sounds like it's in the exhaust on cold starts. The dealer said they were aware of the noise but they didn’t have a fix for it.
Old Nov 8, 2005 | 11:35 PM
Jsd's Avatar
Jsd
A rattle like that sounds like a pooched cat.
If you can't find anything visually, start it up
hold and put a lot of pressure on the exhaust system
with your hand, tighten it up, see if it's rattling against
something. Might just be something loose in the muffler
or a bad cat like I said. Stuff rattles lol process of elimination
is the only way i've ever found noises.
Hey, just for giggles...my heat shield for the muffler
rattles, cause it's cheap and rusts quickly, and the bolt drops
out. Sometimes it does, other times it doesn't. Damn VW's
everything rattles lololololol
Old Nov 10, 2005 | 06:12 PM
  #7
patrick's Avatar
Administrator
have they checked the heat shields?
Old Jan 8, 2006 | 03:16 AM
  #8
sixno1's Avatar
sounds like cv joints to me, i have an older jetta, and it did the same exact thing. Have you hit any bad holes lately?
theNUHF
May 31, 2009 08:26 PM
GFassler
May 1, 2008 06:50 PM
robsjetta
Apr 9, 2007 06:38 PM
crazyhawk99
Nov 14, 2006 02:06 PM
jazznuts699
Oct 16, 2006 08:57 PM
