2001 Wolfsburg Door Lock Issues
I have a 2001 Wolfsburg and the door locks have major issues. The dealer wanted $1500.00 toreplace the Alarm andLockingSystemand well, not in the budget. Are the any suggestions for fixing this? Is this a common problem? Any help would be greatly appreciated.
RE: 2001 Wolfsburg Door Lock Issues
umm, whats the major issue?
Yeah that would have been helpful. Sorry
- Remote door lock works 50% of the time. - Using the key to lock the car does does not allow you to lock all four doors and set the alarm. Again, this is not an all the time problem. - Light does not come anymore when you open the door or when you unlock it with the remote. - The alarm occasionally sets itself on it's own. |
I have a 2002 Jetta TDI with a similar issue. The remote will open the driver's door and trunk but not the passenger or rear doors. The symptom does not change with the second remote. I am able to open all the doors using the button on the inside of the driver's door. The problem surfaced after the car battery discharged due to inactivity. I have charged it and driven it then the radio failed. Removing and replacing the fuse (#45) resolved the radio issue but the door lock problem still remains.
Any suggestions? |
| All times are GMT -5. The time now is 09:19 AM. |
