1999 Jetta Wolfsburg electrical problem
Old May 21, 2010 | 08:33 PM
2jettas2's Avatar
Default 1999 Jetta Wolfsburg electrical problem
Intermittently my Jetta has an issue with several electrical items that will not work. When it occurs the wipers, washers, interior fan and maybe other circuits(rear window defogger) do not work. I can drive off and 5 mins later (without restarting the engine) they will work ok. I had a similar issue with my 98 Jetta and I think the problem was found to be a worn out ignition switch. I have jiggled the switch to see if that would make things work again but no luck. Stopping the engine and restarting sometimes is the fix but not always. Seems like a ghost is in this car.
This car has electric windows that are a real pain but a had a glass installer show me how to fix the window regulators without spending more than $5.00. A tube of epoxy to repair the plastic guide is all it takes but removing the regulator(s) is a job!
Old May 22, 2010 | 10:39 PM
wolfganganna's Avatar
My 98 jettas wipers only work when i turn the bright lights on. I would like to know a cheap way to fix it. any ideas???
Old Jun 9, 2010 | 04:58 PM
afarfalla's Avatar
push all the fuse in their holders, this happened to me, I pushed on all the fuses with my thumb and it solved the problem
MSRockafellow
Jan 31, 2015 08:08 PM
sscorvettezr1
Sep 10, 2011 03:23 PM
xmoex
Feb 9, 2009 01:10 PM
frai_D
Oct 26, 2008 04:54 PM
Talonclaw21
Oct 4, 2008 06:01 PM
