1996 Jetta. Hard Check engine light
Hello,
I have a 96 jetta gls, 2.0 Litter. I really need help to get the check engine to go off. It is super complicated. As of right now I have six codes. They are: P0327 Knock sensor 1 circuit low imput bank 1 or 1 sensor P0440 Evap emission control system malfunction P0133 O2 sensor CKT slow response (bank 1 sensor one) P0171 System too lean P1613 Manufacturer control auxiliary inputs auxiliary outputs P0125 clad loop fuel ctrl insufficient coolant temp When the codes are erased, the light turns off. Then when you start driving it and you give it like gas so that the rpm go over 3 thousand, the car jerks and the check engine comes on. This code that first comes on is the knock sensor which I replaced already. Some of the other things I have replaced are 1. MAF sensor (from a car without a check engine) 2. Oxygen sensor 3. Spark plugs 4. Distributer rotor 5. Distributor cap 6. Spark plug wiring 7. Cleaned the fuel injectors at a fuel injector shop 8. The fuel filter 9. Fuel pump 10. All the belts 11. Both oil pressure sensors 12. Ignition switch My biggest question is why the knock sensor still comes up? I also have a water pump installed that was installed before I got the car. It is installed a little bad and causes the belt not to be 100% lined up with the ac and alternator. Also other symptoms that I have with the car is that it starts up pretty bad sometime, the engine turns over but does not catch the spark until you press the gas pedal all the way. And last but not least is when I am driving almost all the time, you feel a little jerking of the car. Like most people will not notice it at all, but I feel it. So that is basically it. If someone knows how to help please, I really just want to get rid of the check engine and maybe sell it. |
