-   -   1995 blown timing belt... (https://volkswagenforum.com/forum/volkswagen-jetta-bora-19/1995-blown-timing-belt-384/)
ryan123321 Dec 17, 2005 05:34 PM
in a 1995 jetta, the timing belt is blown, but does that mean that the heads are blown too?
imjsavage Dec 19, 2005 03:59 AM
RE: 1995 blown timing belt...
well 9.7 times out of 10, yes. you dont want to just put a new timing belt on, and chance it by trying to start it. the only way you will know is by pulling the head. if you dont pull the head, you can and will do more damage. so trust me on pulling the cylinder head, i've been a master mechanic with mercedes-benz for 6 years now.
89 jetta carat Jan 7, 2006 09:09 PM
on all 8valve engines when you blow the timing belt the cylinder head is fine because the vavles do not interfere with eachother thats only on 8VALVE engines.
