1990 Jetta clutch rebuild...NEED HELP
Old Jun 21, 2006 | 12:30 AM
rileysdad's Avatar
Default 1990 Jetta clutch rebuild...NEED HELP
...NEED HELP, Do I need to completely pull halfshafts?
how do I save the boots? Am I in over my head?
Old Jun 21, 2006 | 02:00 AM
Jsd's Avatar
Jsd
Default RE: 1990 Jetta clutch rebuild...NEED HELP
You could be in over you head. Personally I can't help you with the rebuild but I know there are members on here that could. Just have to wait patiently for an answer. I wish you much luck! Hope some members can help.
-Jeff
Old Jul 3, 2006 | 02:28 AM
rileysdad's Avatar
O.K. Here 's the deal...I have replaced the clutch, and the release bearing. The clutch push rod, running through the trans does not seem to reach the pressure plate. There is no resistance on the clutch arm. It almost seems that the new clutch parts and the release rod are not compatible...rod not long enough. I am running out of ideas. I welcome any new ones. Bottom line, with everyting hooked up, the clutch pedal goes straight to the floor and stays there.
Pulling my hair out in Portland
Old Jul 6, 2006 | 10:28 AM
bagel's Avatar
you need to purge your lines, the piston has to be able to push fluid and release, with air inside all that the pedal will go to the floor ahnd stay there.
Lyryllyn
May 15, 2013 12:51 PM
pattyrobs
Feb 16, 2011 02:52 PM
94tjjetta
Feb 25, 2010 03:30 PM
nite11
Jan 21, 2008 06:49 PM
tommyvr6
Sep 10, 2007 05:23 PM
