07 jetta HID problems...
Old 01-20-2010 | 11:00 AM
RedBowTies88's Avatar
Default 07 jetta HID problems...
Hey guys...new here but not to autoforums im here for my cousin. we attempted to install some HID's in his car last night but ran into many problems hopefully you can point us in the right direction.
for starters he bought 2 H7 kits and 2 relay harnesses from VVME. They are 55w ballast kits (whether this is part of the problem or not im not sure) for starters it looks like there is no way to even remotely make the low beams work with factory pieces becuase it has the twist off thingy so were lost there. we went on to install the high beams.... hooked them up without the harness just to try it and they worked...but only they got just the slightest flicker every few seconds while driving. so we went back to the garage and installed the relay harness and then HOLY HELL they barely work at all. turning them on is like turning on police lights and if you wait a second they smooth out. but then soon as you touch the throttle bam right back to strobe mode the ground is good and attached to the frame...anyone have a solution to these problems?
thanks.
jettaray87
08-26-2008 11:36 PM
arawas
04-19-2008 10:41 PM
intel_908
01-12-2008 12:17 AM
63 MPG
10-20-2007 03:09 AM
John
10-09-2007 05:38 PM
Quick Reply: 07 jetta HID problems...
