04' Jetta cylinder misfire help
About six months ago my check engine light had gone on and the code was a P0301. I replaced the coil pack, wires, and plugs and the problem had gone away. A month ago I got another light with the codes P0301 and P0353. I understand one is a cylinder 3 misfire and the other had something to do with the ignition coil. It is a very intermittent problem. Sometimes the light flashes and the car shakes like a misfire and sometimes the light is completely off and the problem is gone. Any ideas on where I should start looking to solve his problem? Any help is greatly appreciated.
Thanks! |
Welcome to the forum. http://i10.photobucket.com/albums/a1.../VWwelcome.gif
VAG Error Code: 16685 EOBD II Error Code: P0301 Fault Location: Cylinder 1 - Misfire Detected Possible Cause: Wiring. Ignition system. Fuel injectors. Fuel pressure. Running out of fuel. EVAP canister purge valve. Evaporative emission system. Low compression. Base engine problems. Engine Control Module (ECM). Special Notes: This feature search for engine misfire in a specific cylinder. Most of the time the cause for a misfire is a lack of combustion in a cylinder due to absence of spark, poor fuel metering, or poor compression. VAG Error Code: 16737 EOBD II Error Code: P0353 Fault Location: Ignition Coil C, Primary/Secondary - Circuit Malfunction Possible Cause: Wiring. Ignition coil. Ignition amplifier. Engine Control Module (ECM). As taken from my https://volkswagenforum.com/forum/ge...oftware-34973/ |
Thanks for the info its a start on the problem. Any idea where to go next? I had replaced what I thought would be the problem so I don't know where to start checking for problems in the engine bay.
error code table: Diagnostic Trouble Code (DTC) Table Free Download
There are plenty of online OBD error codes but they only tell you
P0301 Cylinder 1 Misfire Detected P0353 Ignition Coil "C" Primary/Secondary Circuit not what to do about it, mine does in alot of cases. |
| All times are GMT -5. The time now is 04:09 AM. |
