04' Jetta P0303 and P0353 help
Old Jun 22, 2013 | 09:52 PM
Dkongkill's Avatar
Default 04' Jetta cylinder misfire help
About six months ago my check engine light had gone on and the code was a P0301. I replaced the coil pack, wires, and plugs and the problem had gone away. A month ago I got another light with the codes P0301 and P0353. I understand one is a cylinder 3 misfire and the other had something to do with the ignition coil. It is a very intermittent problem. Sometimes the light flashes and the car shakes like a misfire and sometimes the light is completely off and the problem is gone. Any ideas on where I should start looking to solve his problem? Any help is greatly appreciated.
Thanks!
Old Jun 23, 2013 | 07:28 AM
Welcome to the forum.
VAG Error Code: 16685
EOBD II Error Code: P0301
Fault Location:
Cylinder 1 - Misfire Detected
Possible Cause:
Wiring.
Ignition system.
Fuel injectors.
Fuel pressure.
Running out of fuel.
EVAP canister purge valve.
Evaporative emission system.
Low compression.
Base engine problems.
Engine Control Module (ECM).
Special Notes:
VAG Error Code: 16737
EOBD II Error Code: P0353
Fault Location:
Ignition Coil C, Primary/Secondary - Circuit Malfunction
Possible Cause:
Wiring.
Ignition coil.
Ignition amplifier.
Old Jun 24, 2013 | 07:52 AM
Dkongkill's Avatar
Thanks for the info its a start on the problem. Any idea where to go next? I had replaced what I thought would be the problem so I don't know where to start checking for problems in the engine bay.
Old Jun 24, 2013 | 11:02 PM
Victor520's Avatar
Member
Old Jun 25, 2013 | 06:55 AM
There are plenty of online OBD error codes but they only tell you
P0301 Cylinder 1 Misfire Detected
P0353 Ignition Coil "C" Primary/Secondary Circuit
not what to do about it, mine does in alot of cases.
jestepp
Apr 21, 2022 02:59 PM
photogirl7
Jan 14, 2015 08:05 PM
ndial2498
Aug 9, 2011 10:50 PM
skutsko
Apr 11, 2010 05:45 PM
jzambon
Jan 3, 2009 06:13 PM
