VW Golf GTI problem
I am frequently receiving engine failure alarm (yellow engine symbol)
The problem is isolated to the pot meter informing about the position of what the workshop call , short and long exhaust pipe. It has happen 3 times during the last 5 month. The fault is deleted by my VW workshop every time. As replacement of exh.. manifold is very costly and might not be the problem, but rather a software/computer problem , I am asking other members if they have experienced the same problem. When the fault is active it does not seem to have any influence of the cars performance. Knud |
Default Welcome to Volkswagen Forum - Rules & Recommendations You need to get your motor scanned (preferably with VAG-COM\VCDS) for any error codes logged in the ecu and post them, that will save a lot of guessing. Post moved to correct section as OP can't read sub forum titles. ;) |
