Too Hot!
Old Aug 28, 2006 | 10:15 PM
spank's Avatar
Default Too Hot!
Hey guys!
I found this forum looking into an issue im having with my 2003 GTI 1.8T. 46K Miles
I was driving lastnight and I started to overheat. I turned off the AC, cranked the heat and poped her outta gear. Right away the temp went back down to 190. The car is totally fine if its running, just when its in gear it overheats.
Any ideas?
Old Aug 29, 2006 | 10:44 AM
bagel's Avatar
Default RE: Too Hot!
Welcome! As far as your problem goes, not a clue. That's pretty weird, never heard of that happening, but will def do some research on it. If you find out anything, please let us all know.
Old Oct 4, 2006 | 09:30 PM
GTI.8T03's Avatar
if i was u i would check the water pump but there is other few things that could of went but my guess water pump good luck
Old Oct 25, 2006 | 09:41 PM
SpeedyCorky's Avatar
if i had a turbo, i'd for sure install a oil cooler
such would help your over heating issue
Aug 26, 2019 05:42 PM
centerline
Jan 18, 2011 03:04 PM
monkfishdan
Jan 11, 2007 06:00 AM
NoobGTI07
Dec 6, 2006 08:47 AM
ThatsLife
Aug 23, 2006 03:04 AM
