Random Fail to start 97 TDI
Old May 30, 2012 | 01:21 PM
mason326's Avatar
Default Random Fail to start 97 TDI
Hi, I have a 97 Passat TDI (4 cylinder) and sometimes it simply fails to start. The starter and battery are fine and there does not seem to be any pattern to these failures. I am convinced it is not getting any fuel, or that there is air in the fuel. If anyone has any insight that would be appreciated. Also does anyone know if there is a fuel pump in the tank or if it uses a vacuum to get the fuel to the injection pump. Thanks for reading!
Old Jun 4, 2012 | 08:30 AM
automanix's Avatar
I would recommend you to get your air filters and most important the Carburetor checked. if needed get your carburetor replaced if faulty. and i dont think so there are any pumps in the fuel tank as far as my knowledge is concerned. All the best
Old Jun 4, 2012 | 08:02 PM
Excuse me automanix its a TDI and therefore a diesel engine.
Does the glow plug warning light up on the dash?
If you have no record of a fuel filter change then change it so you know its new.
Draining or changing the VW TDI fuel filter and priming the fuel system
I don't think there is a fuel pump in the tank this is fitted on later models.
Old Jun 5, 2012 | 11:07 AM
mason326's Avatar
The glow plug light does come on and the car often started easily in the winter and would then fail in warm weather even after it had been warmed up so I am thinking it is not the glow plugs but I hear they are an easy job so I will try that. I have also just replaced the fuel filter because that was my original thought.
Old Jun 12, 2012 | 11:00 AM
mason326's Avatar
The car starts if you run a wire from the positive side of the battery to the injection pump shut off but i am not sure where the loose connection is.
diyobd2
Feb 9, 2014 09:31 PM
Oct 19, 2010 06:18 AM
Thrifty
Jun 24, 2010 11:54 AM
picasso
May 24, 2010 10:15 AM
pengwin
Jan 29, 2007 11:15 PM
