-   Volkswagen GTi / TDi (https://volkswagenforum.com/forum/volkswagen-gti-tdi-26/)
-   -   i need some advice! (https://volkswagenforum.com/forum/volkswagen-gti-tdi-26/i-need-some-advice-11380/)
dkashbmx Apr 3, 2009 10:09 AM
i need some advice!
ok so i just bought a 91 gti 16v and it has the original grille on it with four head lights. i just bought an aftermarket grille that has two outer pockets for only two headlights. i want to get rid of the inner two and just keep the outside two but when i unhook the inner two the outer two lights wont work. is there any advice to this problem? thanks,
racerx002 Apr 3, 2009 06:53 PM
You could just use a jumper wire in between harnesses. Just figure out the power wire they all share.
dkashbmx Apr 5, 2009 10:06 PM
k
thanks man ill check that out!
