HELP! 2006 TDI Jetta will not start
Our 2006 TDI cut off on my son as he was going down the highway. No noise, etc., just stopped. It acts as if it wants to crank but will not. Mechanic has replaced cam position sensor, crank sensor, evaluated fuel pump, changed fuel filter - still won't start. Now he says it appears there's something broken in the motor and I need to replace or rebuild the motor. As I have no money trees in the back yard, is it really likely possible the motor is gone in an '06 TDI with 130,000 miles?
I would get a second opinion from another mechanic, sounds like you are getting the shaft.
the TDI motors are nearly indestructible. |
Originally Posted by A Rehder
(Post 51475)
Do you know the service history of this motor? At 130k the timing belt should have been changed at 80k did the mechanic test for this? Now if it does crank over and it mechanically sound then it sounds like a lack of fuel problem. A good TDI forum you should browse http://www.myturbodiesel.com/forum/ ;) |
Fuel Cut-Off Valve/Sensor ? Loss of Power
Driving down the road and the TDI engine losses power or stops running; this sounds familiar. I can't speak for the 2006, but on the pre-2000 TDI models the fuel cut-off valve/sensor failure is often the culprit of sudden loss of power/engine shut-down. This valve/sensor is rather inexpensive to purchase and easy to replace on pre-2000.
may be some professional diagnostic tool will helps you ...
you can go to auobd2.com to have a look...maybe.... |
i m so sorrry i dont know either
Sounds like timing belt, bad about 2000.00 repair at Vw if the head isn't damaged to bad.
men Nike Free shoes caught the eyes of many. In 2011 when the was introduced. The mention of air cushions, men Nike Free shoes designers know better, bigger bubble to develop, then use newly developed known as blow-molding technology . These shoes are also open to challenge the internationally known artists to participate in advertising design.
Because the downward movement of the body repeated intense exercise and sport performance will be much damage, the men Nike Free shoes cargo movements share a strong influence, and the imperious way, special gas poured solid layer of rubber Synthetic Gas Nike Free shoes sale mitigate the impact of external forces will not be lost! http://hicheapshoes.com |
The mention of air cushions, men Nike Free shoes designers know better, bigger bubble to develop, then use newly developed known as blow-molding technology.
M4V is a kind of format used for video podcasts, based on a codec used by the QuickTime. This codec is a part of the MPEG-4, a global multimedia standard and this standard was introduced to provide optimized video podcasts for the video iPod.
Professional m4v to dvd mac software can help you to convert m4v to dvd mac. Step1. Add M4V video Click the "+" button to add the M4V video files you want to burn, you also can drag the M4V video directly to the program. The added M4V videos will be shown in thumbnails in the right pane. Step2. Edit M4V Video You can Crop M4V Video, Trim M4V Video with the editing functions, you also can choose to customize DVD Menu and "Preview" the M4V video, editing function for mac is just optional. You can skip to the next step – click the "Burn" button to burn m4v to dvd on mac directly. Step3. Start Burning M4V Video to DVD After all is set, please click Burn button to burn m4v to dvd on mac. Note: It will take you about 30 minutes to finish mac m4v to dvd conversion . Then, you can enjoy and share the DVD which was burned from M4V Video on your DVD player! |
