-   Volkswagen GTi / TDi (https://volkswagenforum.com/forum/volkswagen-gti-tdi-26/)
-   -   GTI tailight fuse keeps blowing everytime i turn the light switch. (https://volkswagenforum.com/forum/volkswagen-gti-tdi-26/gti-tailight-fuse-keeps-blowing-everytime-i-turn-light-switch-34566/)
romoguy15 Feb 22, 2012 10:22 PM
Hey guys im new to the forum. I have been having a problem with one of my tail lights not working for the longest time, and just recently i notice that everytime i turn the light switch fuse #23 blows. Its the park light. The car is an 03 gti btw. Ive searched online and didnt find any solutions to a fix and was wondering if anybody can help? I would really appreciate it.
Keithuk Feb 23, 2012 07:25 AM
1 Attachment(s)
Welcome to the forum. Attachment 3208
Well if it keeps on blowing this fuse then you need to check that circuit with a multimeter. You need to disconnect the battery when you using ohms as voltage will blow the meter.
Does that Fuse #23 cover any other circuit apart from the tail lights, what amp rating is it?
romoguy15 Feb 24, 2012 07:56 AM
Its a 5 amp. I dont know what other circuits its running on. Maybe the illuminations inside because just yesterday my illumination stopped working. I can try tp get a multi meter, but idk what to be looking for?
Keithuk Feb 24, 2012 07:41 PM
Yes F23 (5 amp) is the fuse for the LH side lamp/tail lamps. Now if something blows this fuse everytime then you have a short on that circuit which you should be able to find with a multimeter.
romoguy15 Feb 25, 2012 09:34 AM
Do you think it could be the headlamp switch thats short circuited? Since now when i turn the swtich, my illuminations doesnt work either.
Keithuk Feb 25, 2012 06:56 PM
It could be as its part of the ciruit test it.
romoguy15 Feb 26, 2012 09:54 AM
Alright, ill try to buy a new switch and see what happens. Thanks for all ur replies. Idk exactly when i can buy the part. But when i do, ill make sure to keep u informed. Thanks again.
Keithuk Feb 26, 2012 05:19 PM
1 Attachment(s)
eBay is a good place to search or Attachment 3200 them.
romoguy15 Feb 27, 2012 09:32 PM
Okay, so i will be getting a headlamp switch on saturday and ill try to install it to see if it fixes it. Ill let you know what happens
romoguy15 Mar 3, 2012 02:56 PM
Update, I changed the headlight switch and it did not fix it. The minute i plugged the switch in it blew the fuse. I still have no illumination and left rear brake light. Im out of ideas?? Has anyone else experienced this problem before?
