Buying mkIV 1.8T How much power to expect?
Im about to buy a 2003 Gti 1.8T. But the question in my mind is how much power to expect from the one of them with a stock 1.8T engine with stock turbine and the following mods:
1.Wider turbine inlet pipie 2.down pipe 3.catback 4.bypass blow off(if no check engine issues) else I just get a normal forge which recirculates the air in 5.intake 6.computer reprogramming(the one which has the 3 modes which is vallet, normal fuel and high octane. this one get the max out of the stock turbine, I believe about 19psi) |
