Broken engine block
Has anyone had a problem with the engine motor mount breaking and chunking off the engine block where it is attached? I have a 99 Jetta TDI and I think this is what the problem is. I'm hoping it is just the engine motor mount.
RE: Broken engine block
Yes...on my 2003 Jetta...
We have a fix for the Broken engine block!
We have designed and built a set of CNC aluminum brackets to repair the broken gas and diesel engine blocks in 1998 and newer VW and Audi four cylinder cars. When the cast iron "ear" breaks off of your engine you can replace it with a VanGogh engine block fix kit listed here:
http://www.dieselgeek.com/servlet/Ca...ck+Repair+Kits Jim dieselgeek.com |
2001 vr6
Do you have anything that will fix a 2001 VR6 moter mount on the passanger side?
