Air in fuel line
Old Jun 15, 2006 | 09:56 AM
grimwl's Avatar
Default Air in fuel line
Hi there
I have A major problem with airbubbles comming out of the fuel filter clear line going into the fuel pump.Iv changed my fuel filter and traced all fuel lines as far as possible no problems found as such. If anybody else as had this problem and as a fix please can you help with any advice.
My car is a Vw Golf 19 tdi 2000 plate.
Many thanks
Lee
Old Jun 15, 2006 | 10:37 AM
bagel's Avatar
Default RE: Air in fuel line
ok for 1, How did you get air in the fuel lines? 2, let your car run for a couple secs with the gas cap open, this SHOULD purge any air.
Old Jun 15, 2006 | 05:52 PM
stv fox's Avatar
how is it affecting the car.how much fuel is in the tank
Old Jun 16, 2006 | 04:41 AM
grimwl's Avatar
Hi Bagel
Thanks for your input.Tried your Idea last night still did not cure the problem.Iv had this problem now for about a year Iv changed the fuel filter a few times and also the 'o' rings,On the motorway the car gets very sluggish on overtaking and somtimes I have to pull over fills like the turbo cuts out??????
Old Jun 16, 2006 | 02:22 PM
grimwl's Avatar
Hi Stv fox
Just driven my golf back home on the motorway. In the heat its to be even more sluggish and also when I have full to 1/2 a tank it seems to be sluggish??????
Old Jun 19, 2006 | 11:49 AM
bagel's Avatar
umm if it's not the throttle body, or dirty injectors, than I'm sorry I dunno what it could, would have to research more.
sowens
Mar 15, 2010 06:14 PM
emden1822
Sep 8, 2007 01:35 PM
duckmn56
Jul 24, 2007 06:22 PM
baldy_54
May 6, 2007 07:28 AM
sweetbabbyjoejoe
Aug 20, 2006 11:14 PM
