Programming keyless remote...
I'm trying to program the remote for my 97 Golf. For some reason, I can't get it to program. I've tried to different ideas from googling around.
IDEA #1. Remote Control Programming (1997 ON) Procedure 1. Switch Ignition ON and leave the key in the ignition. 2. Mechanically lock the vehicle using the Drivers door using a second key. 3. Using the remote control press the Unlock button once, and the horn will sound once. 4. Wait 6 seconds and press the unlock button once to activate the coding procedure. The remote control will now be programmed. IDEA #2 .....As long as you've got 2 key blades you can re-sync the fobs to the car. Open car, put 1st key in ignition and turn on, shut door and lock with second key then press and hold unlock button on remote for a couple of seconds. Unlock car with key, turn off ignition remove key, shut door and try the remote.... should now be re-sync'd to the car. Repeat with 2nd fob and your done. Neither of these work. Does anyone have the right idea? |
