No power to dash now car won't start?
Hi , yesturday i parked my car up as normal and everything was fine.
Today i went to go out in my car i unlocked it and noticed nothing lit up on the dash so i tryed starting it i had no ignition or any display on dash it was compleatly dead the car did start up but only for 1-2 secs then cut out.The headlights ,window wipers,and stereo works the battery seems fine i also checked all the fuses thay seem fine and i tryed the spare key but still the same? Has any1 else had this problem or know what it could be?# I would be very greatful for any help cheers:confused: My car is a 2004 vw golf tdi 1.9 *update* Its ok i fixed it meself ??! |
VW
Originally Posted by st0ned9
(Post 56127)
VW
Your battery is probably dead. It will have enough power to unlock the doors, roll down windows, etc but may no have enough "umph" to start the car. If you have voltmeter then see if you have 12 volts DC at the battery terminals. If you have anything below that amount (after trying to start it) then that could be the culprit.
2 Attachment(s)
(Post 56127)
The other problem that VW's suffer with is the 109 power relay in the fuse/relay box under the bonnet. A faulty one of those will let you crank the engine but it won't start. I would get a spare on and keep it in the car just in case it does fail one day. My other suggestion is to join a good TDI forum Myturbodiesel we have this problem coming up quite regularly. There are loads of other useful info for TDI's on there. |
how did u fix it yourself?? i have same problem this morning!
(Post 56127)
Originally Posted by silvergolf
(Post 56367)
Vag-com
Originally Posted by Keithuk
(Post 56385)
We don't know he hasn't been back since.
How did I fix it
It was very strange?
As I said the car was fine when I parked it up the next day it wouldn't start What I did was disconnect the battery for about 3 mins all the fuses where fine the strange thing was that it still was the same it was getting dark so I thought I would leave it till the next day before trying to fix it. Anyway the next day I thought rite I will take both me keys out but try the spare key 1st .. I unlocked the car with the spare key and I was shocked to see that the dash lite up and the car started and worked fine and has been ok since but I been useing my spare key to be on the safe side. So I surpose the answer to your question on how I fixed it was disconnect the battery for about 3 mins leave it overnight and tin the morning use the spare key if you have 1 lol sounds strange but that's what I did.:confused: |
Att: SilverGolf
(Post 56367)
How did you solve your issue? I have the exact same issue. |
| All times are GMT -5. The time now is 05:05 AM. |
