-   -   no fuel (https://volkswagenforum.com/forum/volkswagen-golf-22/no-fuel-347/)
cotch Nov 30, 2005 01:11 PM
no fuel
I have a problem with my 1.8 single point injection golf Kreg 1993 MK3
The car suffered from a split in the intermediate flange between the carb and manifold (isn't flange and fantastic word flange,flange,flange). I replaced the flange and thought that was the end of my probkems, but still there is no fuel supply to the engine, the fuel pump works fine but no fuel makes it through the injection system so no go.
any ideas
Jsd Nov 30, 2005 08:08 PM
RE: no fuel
Did you check the filter? The fuel lines? Doube check everything...oh, don't forget to put gas in the car (lol j/k)
cotch Dec 1, 2005 09:22 AM
RE: no fuel
I have a good fuel supply to the single point injector with fuel inlet pipe disconnected and the ignition switched on petrol everywhere. What controls the carb/injection system
89 jetta carat Jan 7, 2006 09:47 PM
RE: no fuel
sounds like your ecu is telling you injectors to stay closed. i would check the ecu
