Need help interpreting ENGINE CODES...
Old May 18, 2008 | 03:19 AM
tcaradonna's Avatar
Default Need help interpreting ENGINE CODES...
Code Gurus,
My check engine light went on recently so I got a vagcom cable to read them out--3 of them. Now that I have them, I have no idea what they mean or where to go from here.
Can anyone look at my vagcom transcript and offer me some suggestions? This is for a 2001 VW Golf 2.0L A/T.
Thank you for your help!
Here is the transcript...
Saturday,17,May,2008,23:37:52:17968
VAG-COM Version: Release 704.1
Data version: 20071016
Chassis Type: 1J - VW Golf/Bora IV
Scan: 01 02 03 08 15 16 17 19 22 29 35 36 37 39 46 47 55 56 57 75
76
Mileage: 88890km/55233miles
Address 01: Engine Labels: None
Part No: 06A 906 032 BQ
Component: 2.0l R4/2V G *3657
Coding: 00003
Shop #: WSC 00000
3 Faults Found:
17551 - Load Calculation Cross Check: Upper Limit Exceeded
P1143 - 35-00 - -
16804 - Catalyst System; Bank 1: Efficiency Below Threshold
P0420 - 35-00 - -
17574 - Long Term Fuel Trim Additive Air; Bank 1; Range 2: System too Rich
P1166 - 35-00 - -
Readiness: 0000 0000
Old May 18, 2008 | 10:16 AM
kdfvwmann's Avatar
Default RE: Need help interpreting ENGINE CODES...
go to this web address for OBD II Codes!
http://autorepair.about.com/cs/troub...l/bl_obd_3.htm
Old May 18, 2008 | 12:24 PM
tcaradonna's Avatar
Thanks for the reply. I checked out that website, but 2 of the codes are not listed there and the other provides the same description that the vagcom gave me. What I'm having trouble with is the interpretation of them. What the heck is it trying to tell me?
Here are my feeble guesses:
P1143 - 35-00 - -
**No Clue
P0420 - 35-00 - -
**Is this coming from the post-cat O2 sensor? Maybe I have a problem with the cat or the o2 sensor itself?
P1166 - 35-00 - -
**not enough air can get in system? air filter problem?
THANKS!!
Torchia32
Oct 24, 2013 07:19 PM
Jan 19, 2011 11:44 PM
ej6kidd
Apr 20, 2010 01:04 PM
lilngineer
May 2, 2008 07:57 PM
lilngineer
May 2, 2008 09:42 AM
