mystery L.E.D. draining my battery. help?
Old Jan 6, 2008 | 05:12 PM
aldo's Avatar
Default mystery L.E.D. draining my battery. help?
Dear All
I have a mysterious L.E.D light which is draining my battery.
The car: VW Golf MkIV 1.6S Auto. Year 2000. Right hand drive.
The light: a red LED positioned to the right of the hazard and demister lights. This light doesn't appear to do anything. My suspicion is it has something to do with the alarm (which doesn't work). The impression is that the alarm is active. It came on recently of its own accord and now it won't go off. Since then my car battery has drained twice. I think the little L.E.D. could drain it because my car can be left unused for a week or so (2000 miles a year).
Does anyone know what it's for or how to turn it off (without just breaking it off).
many thanks
Aldo
Old Jan 6, 2008 | 05:54 PM
Pinge1000's Avatar
Default RE: mystery L.E.D. draining my battery. help?
First question?
Was there an alarm system in the car for sure? if yes;
I think the drain is caused by the alram itself.
IF YES, find out where the brain for the alarm is. most likely under the steering column, go to the box, if alarm not working then unplug all the wires that are going to brain.
The wires for the LED will probably be two thin wires that go to the LED, disconnecting these will solve the light issue.
Obviously, there could be other factors, but maybe this will help.
Good Luck
Old Jan 6, 2008 | 06:00 PM
aldo's Avatar
Thanks for the quick reply. I'm wondering if I should get the alarm fixed. I believe this can be expensive. Another issue is the the remote central locking doesn't work. I'm thinking this is related to the alarm system. How this relates to the light, I'm not sure.
many thanks again
Aldo
aldo's Avatar
many thanks again
Aldo
Vw03
Jan 30, 2014 06:11 AM
cscott37
Oct 26, 2013 05:33 PM
acsamples79
Aug 4, 2011 07:04 AM
spiper122
Dec 27, 2010 07:08 AM
c2stone
Oct 4, 2010 03:11 PM
