HELP Remove pressure plate
I remove the tranny, unbolted the flywheel, the clutch plate came out, but the pressre plate wont disconnect from motor. Any comments.
Thank you, Doing it at this moment |
I don't know how you've managed to do that because you have to remove the pressure plate before you can undo the flywheel bolts?
my bad I got em backwards. but its all good i got the new clutch and put baack together last weekend
| All times are GMT -5. The time now is 09:31 AM. |
