Heaters / Air Con
Heaters / Air Con
Hi All!
Got a problem was just after a bit of advise really!
My air con/heaters pick when they want to work, i took it to a local guy/friend i know, and hes baffled because he says he cant find whats up with it!
anyone got any suggestions on what it could be?
Ta
Ta
RE: Heaters / Air Con
The following information could help you in your problem. The switch of the A/C system is low-pressured. If the pressure gets too low the compressor will be shut off. This will protect the compressor to destroy itself. You should aware on how much refrigerant is still on your system. Too much refrigerant will brings poor cooling ability.
_____________________________
Scottsdale New and Used Cars
10-23-2010 06:02 AM
