-   -   Cooling Fans Running With Key Out 2007 Rabbit (https://volkswagenforum.com/forum/volkswagen-golf-22/cooling-fans-running-key-out-2007-rabbit-38008/)
Gorhad Oct 14, 2019 03:55 AM
Hi all
Out of know where the car can be sat on drive not recently driven and the cooling fans kick in with keys out and stays on until I put the key back in ignition and turn car on.
I'm sure at some stage I'm going to be out return back to car and battery is dead…Thing is its only just started doing this today after a bringing it out from a week in garage (doing oil pan seal) I know it's hot in FL but seems really odd
Put scanner on and no codes at all checked coolant level, all is good
Thanks in advance for any advice
Keithuk Oct 14, 2019 06:57 AM
Your other post in 2011 is for 2001 VW Passat E6 key.
Scanned with which scanner not VAG-COM\VCDS?
