-   -   check engine (https://volkswagenforum.com/forum/volkswagen-golf-22/check-engine-6451/)
dieseljunkie12 Sep 16, 2008 07:47 PM
check engine
check engine light is on. code reads as secondary air flow? something along those lines. have any of you guys ever had this one come about? thanks in advance.
dieseljunkie12 Sep 16, 2008 08:02 PM
RE: check engine
i forgot to add its a 1996 with a 2.0L.
Jrailer Sep 16, 2008 09:33 PM
RE: check engine
does your 96 have a air pump?
if so check the small vacume line to the deverter valve
that is the valve the big air pump hose goes to the small lines crack all the time
jellobox Sep 17, 2008 07:46 PM
RE: check engine
take it to autozone and have them to test it with an obd2 tester and run the code. the can break it down and tell you exactly what is causing it.
