check engine
Old Sep 16, 2008 | 07:47 PM
dieseljunkie12's Avatar
Default check engine
check engine light is on. code reads as secondary air flow? something along those lines. have any of you guys ever had this one come about? thanks in advance.
Old Sep 16, 2008 | 08:02 PM
Default RE: check engine
i forgot to add its a 1996 with a 2.0L.
Old Sep 16, 2008 | 09:33 PM
Jrailer's Avatar
does your 96 have a air pump?
if so check the small vacume line to the deverter valve
that is the valve the big air pump hose goes to the small lines crack all the time
Old Sep 17, 2008 | 07:46 PM
jellobox's Avatar
take it to autozone and have them to test it with an obd2 tester and run the code. the can break it down and tell you exactly what is causing it.
lilngineer
May 2, 2008 07:57 PM
lilngineer
May 2, 2008 09:42 AM
drioux
Apr 1, 2008 12:47 PM
magea
Oct 18, 2007 08:12 PM
magea
Oct 8, 2007 10:55 PM
