98 GOLF GL , 2 LITER GAS
Old May 18, 2008 | 10:23 AM
kdfvwmann's Avatar
Default 98 GOLF GL , 2 LITER GAS
NO POWER 2000-3000 RPM, OBD II CODES: P0300,P0302,P0304,
FUEL PRESSURES OK, 3 BAR/44PSI @ IDLE VACUUM OFF @ PRESS REG,
2.5 BAR / 36 PSI VACUUM ON @ PRESS REG,
ENGINE OFF, 5 MINUTE RESIDUAL PRESS + 2BAR /35 PSI,
NEW IGN COIL, IGN CABLES, SPARK PLUGS, DISTR. CAP + ROTOR,
IT RUN OK PRIOR TO GETTING A NEW EXHAUST SYSTEM WELDED ON,
EVEN TRIED A NEW AIR MASS METER, ALL TO NO AVAIL,
STRANGE OBSERVATION; WITH THE 3 PRONG PLUG DISCONNECTED @ DISTRIBUTOR,
ENGINE WILL START AND IDLE.
WHAT ELSE NEED I CHECK OUT, I DO NOT HAVE A DECENT WIRING DIAGRAM,
(ALL WE HAVE IS A USELESS HAYNES MANUAL).
PLEASE HELP!
Old May 19, 2008 | 09:32 PM
kdfvwmann's Avatar
Default RE: 98 GOLF GL , 2 LITER GAS
ITS THE BASICS!
FOUND OUT THAT THE CATALYTIC CONVERTER HAD A LOOSE CLUMP OF CATALYST @ THE INLET CHAMBER WHICH OVER TIME BEAT THE REAR CATALYTS' HONEYCOMBS ALL TO HELL AND RESULTED IN A MASSIVE FLOW RESTRICTION DURING ACCELLERATION!
(FUEL FLOW OK, 1 + LITER IN 30 SECONDS)
MANY THANKS TO WAYNE'S VW REPAIR IN WEST VALLEY CITY UTAH FOR HIS
TIMELY AND USEFUL ADVICE, GREAT GUY , GREAT HELP !
mrhead
Feb 8, 2009 02:55 PM
ummba
Oct 30, 2008 07:14 PM
fasteddie
Aug 10, 2008 07:58 AM
lightorch
May 6, 2006 01:43 AM
lightorch
Nov 28, 2005 03:02 PM
