90 Golf Cold Idle problems
Old Jul 21, 2008 | 07:36 PM
dsontos's Avatar
Default 90 Golf Cold Idle problems
1990 VW Golf 1.8L Digifant II fuel injection - when cold, idle fluctuates between 1000 and 2000 rpm for about 2-3 minutes (summer time) then drops down to normal idle and runs fine after. Replaced distributor, coolant temperature sensor, spark plugs, and oxygen sensor. Swaped out with another car the computer, air box, idle speed motor. I've run injector cleaner in the gas tank with no difference. I'm stumped
Old Jul 21, 2008 | 10:48 PM
bagel's Avatar
Default RE: 90 Golf Cold Idle problems
the idle goes to normal after 2-3 minutes? Well it is a 1990; is there any running problems when you're driving??
Old Jul 22, 2008 | 06:18 AM
dsontos's Avatar
The car seems to run fine after the initial warmup.
Old Jul 23, 2008 | 11:37 PM
bagel's Avatar
I've seen older cars do that from time to time. I think they make some gumout or some other cleaner that should take care of that. check with auto parts store.
huyuhy
Oct 13, 2011 01:09 PM
Uppi
May 29, 2010 09:47 PM
oxygen454
Mar 18, 2009 09:33 AM
rocketsci
Jan 13, 2008 09:01 AM
Qhergt
Jun 24, 2007 08:44 PM
