20th AE HELP
Okay so I bottomed my car very good. Now it's making some grinding noise in the front right passenger side of my car. When it burn left it does it the most. It and gringing sound for sure it makes me Kringe. Is there anything on that side or location if I bottomed out could be damaged to make that kind of noise. It's not a constant noise though. If I turn left it does it the most . What could this be and here is a video of the sound.
1 Attachment(s)
Welcome to the forum. Attachment 2749
You need to look underneath for something dragging on the floor or around a driveshaft. https://volkswagenforum.com/forum/ne...gnature-34185/ |
it could be the fender liner scraping the tire when you turn. i recently put my car on a lift and found that i was missing a screw holding the liner and a hole worn in it. and she was making a funny noise when i turned sharp or went over a long series of bumps. easy fix. hopefully its the same with you.
