2006 Golf GL with ENGINE FAILURE @127K miles
Old 02-15-2018, 08:50 PM
Jurgen's Avatar
Exclamation 2006 Golf GL with ENGINE FAILURE @127K miles
Bought VW GOLF GL 2006 for my daughter from 1st owner @70K miles. Had full 100K miles service done. Now have 127K on it and the engine just locked up after parking it.
Had all fluids at proper level - oil and coolant. Mechanic cannot figure out why it locked, cannot crank it. Is offering to replace the engine for $1,750. Why is this happening at this low mileage and having maintained the car well? German quality parts? Anybody else who has run into this issue? PLEASE HELP. Thanks!
Attached Thumbnails 2006 Golf GL with ENGINE FAILURE @127K miles-averys-vw-golf.jpg
Old 02-16-2018, 05:47 AM
You don't say which engine size and type it is. Without seeing the vehicle its not easy to diagnose. I would check the timing belt hasn't broke, you mechanic should have checked that.
If you've had this Golf from 70k have you had the timing belt changed since?
Old 02-19-2018, 03:18 PM
Jurgen's Avatar
Was a VW Golf 2.0 GL gas engine and yes, timing belt was changed at 110K miles.
Issue has been resolved recently. Took it to another mechanic and he detected it was the starter after all that locked up in the engine. $200 fix instead of multiple thousand $ for engine replacement. Runs as good as new. Won't be going to the first mechanic again
Thanks for your insights!
Jurgen
furkanakdemir
06-12-2015 12:25 AM
smithers2et
11-29-2011 05:01 PM
nitro121
06-30-2008 10:35 PM
NoVa
05-02-2007 01:35 AM
jitsion
11-12-2005 01:46 PM
Quick Reply: 2006 Golf GL with ENGINE FAILURE @127K miles
