2002 GT TDI Golf with engine trouble
Old Jul 13, 2009 | 09:49 AM
evanfarren101982's Avatar
Default 2002 GT TDI Golf with engine trouble
Hi,
Can Anyone help me fix this problem, I have a Golf GT TDI 115BHP 2002. The problem is only when the car is started from cold. Once it gets to 30 degrees the ESP light comes on and stays on irrespective if you try turn if off using the button, this problem starts with another problem, The engine sounds very bad after 30 degrees, like it is not running on all cylinders, the best way i can describe the noise is like an old type VW beetle!!! to relieve the problem i keep going at as low a speed possible keeping the revs down and wait until the engine reaches its nominal 90 degrees running temp then i stop and restart the engine and it works perfect then. This problem starts every morning and every evening that the car is started from cold.
Thanks in advance! Evan
Old Aug 7, 2009 | 08:58 PM
leftlanedave's Avatar
sounds like the temp switch for the computer not the dash gauge migh be lying down on the job.. It's showing a faulty reading cold untill it warms up , kinda like a bad fuel gauge the wont work below a half tank anything above that works great...
Smokedawg
Dec 21, 2010 02:08 PM
cles1032
Sep 20, 2008 02:09 PM
scar2hand
Jan 13, 2008 09:34 PM
Mitchdakid
Oct 5, 2006 02:39 AM
ken123
Jun 15, 2006 09:06 PM
