2002 2.0L Golf MISFIRE Please Help - RESOLVED
Old Jan 6, 2008 | 10:01 PM
02GolfGLS's Avatar
Default 2002 2.0L Golf MISFIRE Please Help - RESOLVED
I have a 2002 Golf with about 97K on it, with the 2.0L motor. I recently used an oversized drain plug to fix the stripped drain plug and I over filled the oil. Yes, a rookie move and I am not happy about it, but ever since theover fill (I drained it after a short drive) I get a misfire on cyl4 and if I try to drive it more it spreads to cyl3. I replaced the plugs (didn't gap them because I can't find that information), but it ran fine after a couple of misfires. Ran fine for a week or so, its not my primary car, so it sat for about 2 weeks. Its not good since I need to sell it.
I am thinking the O2 sensors are clogged/bad.
Anyone else have any ideas?
[IMG]local://upfiles/6271/BAD6DFC6EA74442DA14074BBDEA843E6.jpg[/IMG]
Old Jan 7, 2008 | 11:23 AM
Smokin Dog's Avatar
Default RE: 2002 2.0L Golf MISFIRE Please Help
When you replaced the spark plugs, did you use the correct plug or did you use those so called super plugs
like split fire and so on. UNLESS the car calls for the
super gismo type plugs every one is so hot for, they will
emitt a ion field and upset the computer, and cause misfire.
Over filling the oil, unless it's a quart or more wont hurt
anything, despite of popular belief. It will not blow seals,
all it will do is blow out what it doesn't need and you
would have a oily engine on the out side.
Old Jan 7, 2008 | 07:15 PM
02GolfGLS's Avatar
They were plat plugs, think Autolites, nothing special. I am thinking my precat O2 sensor is clogged.
Old Jan 7, 2008 | 09:23 PM
Smokin Dog's Avatar
If the o2 sensor is carboned it will turn on the ck engine
light and not miss but run rich. If your car doesn't call for
the palt plugs they could cause the miss. I had a vehicle
that I installed Bosch palt plugs into and it ran great for
a couple of days, then started missing, the dealer said
the plugs were the problem, I didn't believe them, but
installed the plug that was on the chart on the hood and
it fixed the miss.
Old Jan 9, 2008 | 05:41 AM
02GolfGLS's Avatar
okay, what are the stock plugs? the ones I took out said VW on them. I dont want to give a dealership any of my $ since they took me on this POS car.
Old Jan 10, 2008 | 09:43 AM
Smokin Dog's Avatar
There is usually a sticker under the hood area some where
that gives the spark plug type and gap. I would bet the
VW plugs you took out are Bosch, with VW on them. It would be easy enough to make a phone call to a dealer just
to find out what plug goes in it, and then go to the friendly
neighbor hood auto store and purchase them. Even a Hanes
repair manual from Auto Zone will tell you what you need to
know.
Old Jan 13, 2008 | 07:15 PM
  #7
02GolfGLS's Avatar
I tried taking #1 plug and putting it in to cyl #4. Same results, and the plug in #4 originally was definately fouled compared to #1.
Old Jan 14, 2008 | 09:02 PM
  #8
02GolfGLS's Avatar
Going to get a new catalytic converter and a new Mass Air flow sensor, and new O2 sensor...
thats next. I heard there was an emissions recall on the 02 and prior...
I am going to call this 800 number to see if i can still get it, since its good until the car has 100K.
Old Jan 27, 2008 | 08:30 PM
  #9
02GolfGLS's Avatar
I got a recall notice in the mail. My symptoms don't match the acutal recall. I brought the car to the local garage, they will be looking at it this monday. hoping its something simple.
then when its running i will drop it off at the local VW $tealer$hip to see if it needs a new cat. then sell it and never look back.
Old Jan 28, 2008 | 06:57 PM
  #10
02GolfGLS's Avatar
$1300 for repairs. 4 new injectors @ $250a peice, and new ignition wires.
Sell your old golfs ASAP. they burn oil and are WAY under powered. JUNK JUNK JUNK.
Next car will be a Honda/Toyota/Nissan/Kia etc.
