2000 VW GOLF ECU problems
Old Feb 24, 2012 | 08:03 AM
vwtoilet's Avatar
Thumbs down 2000 VW GOLF ECU problems
I had the battery die on my golf, tried to boost it with my high amp boost setting on my battery charger, I've had a mechanic put a VW code reader on the the car and he says that the ecu is producing 38 codes saying all sensors are not functional. This has now caused my car to shift improperly. Can anyone provide some information
Old Feb 24, 2012 | 07:28 PM
Well if you can post all 38 codes I can tell you what each one means.
Old Feb 25, 2012 | 08:32 AM
vwtoilet's Avatar
A mechanic did the test so I dont have the codes, regardless of what the codes mean, there is a larger issue.
Old Feb 25, 2012 | 06:51 PM
Well we don't know where you live because you have nothing in your Location.
You really need to find someone that can do a VAG-COM\VCDS Autoscan and get some error codes. If you live in the US I think AutoZone do a free scan with the hope that you buy something of them.
There is always try Vag-Com Locator Map for someone in your area.
Old Feb 26, 2012 | 03:57 AM
vwtoilet's Avatar
Ok, I will see if I can get a VAG reader and go from there, if I replace the ECU with n ECU that is of the same model number from a auto recycler, will it need to be programmed by VW dealer? Or would it be safe to say its a plug and go situation? Has anyone done this before?
Old Feb 26, 2012 | 05:27 PM
Yes if you get an ECU from a breaker then you'll have to have all your keys programmed by a dealer. Or you could buy VAG TACHO and retrieve the SKC and programme the keys yourself.
Old Mar 31, 2021 | 11:58 AM
  #7
Mike4393's Avatar
Default ECU Repair
Hello
Might be better to have your original part repaired at upfix.com
Here is the service link
https://www.upfix.com/product-catego...ontrol-repair/
Keithuk
May 30, 2019 09:22 AM
Ethan Ason Roney
Dec 31, 2018 07:51 AM
golfingcasper
Aug 4, 2016 06:53 AM
VWlove
Jun 19, 2015 01:30 AM
Aug 9, 2010 10:13 PM
