-   -   1996 golf GL HELP tansmission removal (https://volkswagenforum.com/forum/volkswagen-golf-22/1996-golf-gl-help-tansmission-removal-35265/)
atanasmk3 Sep 15, 2012 04:36 PM
I would like to get to the bottom of this. I have read in different places, you can remove the tranny with out removing it with the engine as a whole. other sites say you can just remove it by it self. you don't need to remove it with the engine.
i have unbolted the axles and disconnected the shifter link edge already. next I am going to undo the bolts that hold the tranny to the motor, then un bolt the mounts and slide the tranny off.
comments please
cheers,
Keithuk Sep 16, 2012 06:26 AM
I've done a clutch on a Polo so it can be done. I can show you how on a mk4 which is going to be similar.
Transmission removal on mk4 VW Jetta TDI , also Golf and New Beetle TDI
Engine/transmission removal DIY 2001 Golf TDI
https://volkswagenforum.com/forum/ne...185/#post56785
