1.8T random/multiple cyl misfire, Help!!
Old Feb 27, 2006 | 12:18 AM
krazzz's Avatar
Default 1.8T random/multiple cyl misfire, Help!!
Hello,
I have more information about my problem. I think that I have ruled out fuel injectors and the coil packs (which are new.) Here is a quick review for those of you who may have not seen my last post. I have a 2000 Passat 1.8T, 5-speed with 105,000 miles. It has recently had problems starting. About one in every five starts it starts very rough and stays that way from 1 min to 5 min. The check engine light comes on and starts to flash. After a few min it run normally and will continue to do so until I shut the car off. The last time I did it I checked the codes. It came back with a P0300- Random/Multiple cylinder misfire, P0301 Cylinder 1 misfire, P0302 Cylinder misfire, and in the past a P0304- Cylinder 4 misfire has shown up. I think I have ruled out fuel related issues and am know looking into spark/timing issues. It seems like most of the ignition controls are in the ECU with the integrated ignition control module. This leaves me with the ECU and camshaft position sensor right? Is there any other sensor involved in spark/timing that could give me a misfire condition? It is strange because it seems to be happening on multiple cylinders. Any other ideas? I can’t really bring it to a dealer because it only does it once a week. The rest of the time it runs flawlessly. Thanks for all your help. I would appreciate and help no matter how small.
Chris
2000 Passat 1.8T 5-speed 105K
Old May 2, 2006 | 12:19 PM
hoboarchery's Avatar
Default RE: 1.8T random/multiple cyl misfire, Help!!
I am having the same issues. 94 golf 150 K, I had my head gasket replaced. I am getting a cam shaft pos sensor error and my distrubitor is loose. I have another error code but it isn't in my book.
Old Jun 8, 2006 | 02:18 PM
stv fox's Avatar
yep check distributer rotor and cap the wrong rotor can screw things up bad check spark wire condition not a bad idea to upgrade check plugs are the oily not gaped right go to dealer for real vw parts.
krazzz
May 29, 2010 10:05 PM
jetta jack
Nov 11, 2007 11:40 AM
krazzz
Feb 27, 2006 12:24 AM
krazzz
Feb 27, 2006 12:20 AM
krazzz
Feb 27, 2006 12:19 AM
