-   Volkswagen Eos (https://volkswagenforum.com/forum/volkswagen-eos-43/)
-   -   Engine Hesitation EOS 2009 (https://volkswagenforum.com/forum/volkswagen-eos-43/engine-hesitation-eos-2009-a-38098/)
eos2009 Feb 12, 2020 08:33 PM
Hi guys.
I have a 2009 Eos and I am experiencing some engine hesitation when the engine is cold and the car is running.
When the engine is idle, there's is no hesitation. It happens as soon as I start to drive and press the gas.
If the car is running on Drive and I don't press the gas, there's no hesitation.
Once the car warms up well, the car runs perfect.
It's usually first time in the day I turn the car on.
No engine light on whatsoever.
Any ideas?
Thanks
Keithuk Feb 13, 2020 08:07 AM
eos2009 Nov 30, 2020 02:47 PM
Hi guys, I got the car scanned but it is showing no error codes at all
However, it keeps producing the hesitation when cold and running
