Engine Hesitation EOS 2009
Hi guys.
I have a 2009 Eos and I am experiencing some engine hesitation when the engine is cold and the car is running.
When the engine is idle, there's is no hesitation. It happens as soon as I start to drive and press the gas.
If the car is running on Drive and I don't press the gas, there's no hesitation.
Once the car warms up well, the car runs perfect.
It's usually first time in the day I turn the car on.
No engine light on whatsoever.
Any ideas?
Thanks
Any ideas?
Thanks
jencvo
Jan 27, 2020 06:44 AM
edmundtaka
Jan 19, 2011 03:30 AM
nicholusjohns
Sep 13, 2010 03:39 AM
