-   Volkswagen Eos (https://volkswagenforum.com/forum/volkswagen-eos-43/)
-   -   2008 VW EOS DSG Transmission Issues (https://volkswagenforum.com/forum/volkswagen-eos-43/2008-vw-eos-dsg-transmission-issues-37871/)
loganlj2 Apr 29, 2019 07:13 PM
Hello,
I have a 2008 VW EOS with an automatic transmission that currently has these two fault codes:
P0733
Pending - P2711
The vehicle will be driving, and then loudly trash, drop into a lower gear, and start flashing PRNDS. It also trashes into reverse and 1st, and rolls a bit forward before reverse engages. If i pull over and "power cycle" the car, it will usually go away for a few minutes before it happens again.
I have my theory on what the issue is, but was hoping to get another take on the issue and either confirm or deny my theory.
Thanks!
Keithuk Apr 30, 2019 08:43 AM
What were those error codes scanned with VAG-COM\VCDS?
VAG Error Code: 17117/21149/001843
EOBD II Error Code: P0733
Fault Location:
Transmission Shift-Range Controller, Gear 3 - Incorrect Ratio
Possible Cause:
Incorrect transmission shifting.
Wiring/Connector(s).
Dirty transmission fluid.
Low transmission fluid.
Sensor Gear Position Indicator faulty.
Gear Solenoids faulty.
Mechanical failure.
Possible Solutions:
Check Sensor Gear Position Indicator.
Check Gear Solenoids.
Special Notes:
The gear monitoring of the Transmission Control Module (TCM) (J217) checks the gear ratio by comparing transmission input and output speed in regard of the currently selected gear. This fault code is being set when recognizing an implausible transmission ratio.
Tech Notes:
Start by inspecting the transmission fluid level and condition, and change fluid if necessary.
When is the code detected?:
P0733 is detected when A/T cannot be shifted to the 3rd gear position even if electrical circuit is good.
Description:
This diagnosis monitors actual gear position by checking the torque converter slip ratio calculated by Transmission Control Module (TCM) as follows:
Torque converter slip ratio = A x C/B.
A: Output shaft revolution signal from speed sensor (revolution sensor).
B: Engine speed signal from Engine Control Module (ECM).
C: Gear ratio determined as gear position which Transmission Control Module (TCM) supposes.
If the actual gear position is higher than the position supposed by Transmission Control Module (TCM), the slip ratio will be more than normal. In case the ratio exceeds the specified value, Transmission Control Module (TCM) judges this diagnosis malfunction.
VAG Error Code: 19143/21181/21188/010001
EOBD II Error Code: P2711
Fault Location:
Unexpected/Implausible Mechanical Gear Disengagement - No Signal/Communication or Incorrect Basic Setting/Adaptation
Possible Cause:
Transmission Malfunction.
Erratic Driving Behaviour.
Double Clutch worn/faulty.
Output Shaft Speed Sensor 1/2 (G501/G502) faulty.
Direct Shift Gearbox (DSG) Mechatronic Control Unit (J743) faulty.
Possible Solutions:
Check Output Shaft Speed Sensor 1/2 (G501/G502).
Check/Replace Direct Shift Gearbox (DSG) Mechatronic Control Unit (J743).
Special Notes:
When found in 6-Speed Direct Shift Gearbox (DSG/02E), check Measuring Value Blocks (MVB) 008. The Output Shaft Speeds should align with the Input Shaft Speed during a Test Drive (Tiptronic in Gear 1/2) with the Clutch engaged.
According to Skoda Technical Product Information (TPI) 2024152 an updated Clutch Set is available which addresses these issues.
Perform Basic Setting
Post moved to the correct sub forum as OP can't read them. ;)
loganlj2 Apr 30, 2019 11:35 AM
Thank you very much for your reply! The codes were taken with a generic ELM scanner, but later confirmed with VCDS Lite. I will check the shaft speeds when I get home from work tonight and report back! It would be awesome if all I had needed this whole time was an $80.00 speed sensor.
loganlj2 Apr 30, 2019 07:01 PM
https://cimg6.ibsrv.net/gimg/volkswa...5aaad3c8ea.jpg
Fault Location:
Possible Cause:
Mechanical failure.
Possible Solutions:
Special Notes:
Tech Notes:
Description:
Fault Location:
Possible Cause:
Possible Solutions:
Special Notes:
Hello -
Just took the car for a test drive while having a passenger monitor the Input / Output shaft speeds. It seems like the output shaft speed stayed around 1/4 what the input shaft speed was the whole drive (around 6 miles) would the next step be to replace the transmission output shaft speed sensor?
Thanks!
Keithuk May 1, 2019 07:19 AM
VCDS Lite has limited functions so you may not be able to show all details.
loganlj2 May 1, 2019 07:59 AM
I actually just purchased VCDS with the HEX-V2 cable last night - i'll try doing this test again when it comes in.
Keithuk May 2, 2019 08:28 AM
When your new cable comes make sure you register it, then you can join Ross-Tech forum
After your intro make a new thread about your problems with a full AutoScan attacked. There are far more experts on there than Google.
Jack richer Dec 20, 2019 11:56 AM
Originally Posted by Keithuk (Post 65277)
When your new cable comes make sure you register it, then you can join <!--td {border: 1px solid #ccc;}br {mso-data-placement:same-cell;}-->filezilla uc browser rufus<a href="http://forums.ross-tech.com/?styleid=5">Ross-Tech forum</a><br /><br />After your intro make a new thread about your problems with a full AutoScan attacked. There are far more experts on there than Google.
<br /><span style="color:#000000;">Thank you very much for your reply!</span>
