Where is water in trunk coming from?
I've had some water issues for awhile now with my wife's 1999 Cabrio. After rains, the inside windows will fog up. I suspected water seeping in around bad window seals. However, I've discovered that the problem is coming from water entering the trunk and pooling around the spare tire well. It appears often to be very fine, almost like mist rather than large puddles. However, it does accumulate over time. Has anyone else had this problem? It appears that the seal around the trunk is fine and is not allowing water in that way. Does anyone know where the water may be entering from?
