What would cause a convertable top NOT to go down- 98 VW Cabrio
Old Feb 21, 2009 | 09:26 PM
remission's Avatar
Default What would cause a convertable top NOT to go down- 98 VW Cabrio
My top wont go down at all. I press the button and can hear a buzzing noise but thats it.
My Ebrake light is messed up and is almost always lit even when not in use. Could this also be why?
I dont know if there is a specific fuse for the top or not, and i heard that there is some type of fluid for the top....
Help please
Old May 20, 2012 | 02:45 PM
inxs321's Avatar
Default relay
under back seat in the middle of floor double relay, not cheap $ 180 CDN . Should get check out by dealer .
Old Sep 29, 2012 | 03:01 PM
flesh wound's Avatar
Ive got the same problem w/my conv. top. Did the relay fix yours?
Old Oct 18, 2012 | 05:54 PM
Tortue's Avatar
If you hear the motor running, then the pump may be malfunctioning or the hydraulic fluid (oil) may have leaked out. It's located in the trunk on the driver's side. remove four screws to get the cover off. The oil reservoir is translucent so you'll know right away if it's empty.
Old Jun 30, 2013 | 04:20 AM
trib's Avatar
remission,
It could be the e-brake thing. On my '99 the e-brake has to be set before the top will work. But also check the hydorlic fluid level. If you find it low, take the passenger seat off and look for leaks. If you find a puddle of oil, don't assume that it's a line, if could be the lift cylinder. Can't give you a price on the lines, (there are three of them) but a cylinder from VW will cost you $400.
As for fluid, you can use the VW stuff ($$$$) or just use regular Hydorolic Oil.
I have a '99 Cabbie and have just gone through the same thing.
Old Sep 13, 2013 | 05:57 AM
AdelleWilliam's Avatar
got my problem solved thanks for those amazing shares here with us, its really superb one
Donna's Cabrio
Oct 13, 2012 01:31 PM
HipHipJorge_20
Nov 7, 2011 12:32 PM
Oct 27, 2010 11:52 PM
SteveT
Apr 7, 2010 09:14 PM
bsimms
Mar 27, 2007 02:45 PM
