Turn Signals and Brake Lights '99 Cabrio
Old Oct 6, 2008 | 02:57 PM
gfeehan's Avatar
Default Turn Signals and Brake Lights '99 Cabrio
My daughters ('99 Cabrio) brake lights and turn signals (rear) seemed to be joined at the hip. When the brake lights are on and the turnsignals get used the whole back end turns into a light show. Say the left turn signal is used (brake pedal pressed) the left brake light flashes strongly and pretty much every other light both left right rear flash dimly!
The fronts operate perfectly.
I replaced the primary turn signal flasher unit and it didnt clean up the problem.
Is my turn signal switch on the steering columnbad?
Her inspection has expired, so I am fairly desperate to get her road legal.
I read somewhere that there was a recall regarding brakelights on this model, but I went on Edmonds.com and could not find it.
thanks all you wise VW people in anticipation
glenn
Old Oct 6, 2008 | 05:26 PM
Jrailer's Avatar
Default RE: Turn Signals and Brake Lights '99 Cabrio
sounds like you have the wrong bulb in it some where
Old Oct 6, 2008 | 06:09 PM
gfeehan's Avatar
I will check, but I am not sure that would be the case as this has happened over eth last month or so and no bulbs have changed - although they may have twisted in their sockets for some crazy "Texas - heat - related reason"!
thanks
Old Oct 8, 2008 | 08:19 PM
gfeehan's Avatar
ok, checked with my daughter and no bulbs have been changed.
Did some more trouble shooting and cleaned all the contacts with the turn signal switch/control on the steering column.
The plot thickens . . . the brake lights work fine with no turn signal switched on, BUT . . . when I turn the headlights on the rear turn signal lights both light up, the turnsignal lights on the dash lightup dimly and when the turn signals get switched on the rear brake light on that side flashes and both the rear turn signal bulbs flash dimly and when the brakes get applied the rear lights just about dissappear with dim random flashing happening.
I am completely lost on this.
Is there a lighting relay that's failing, or the column switch failing or both?
Another thing that I think could be related is, the cruise control now no longer works at all.
thanks again wise ones!
Old Oct 9, 2008 | 07:46 PM
Jrailer's Avatar
PULL THE FRONT MARKER/TURN SIGNAL BULBS OUT AND SEE IF YOU STILL HAVE A PROBLEM
Old Oct 13, 2008 | 12:03 PM
gfeehan's Avatar
OK - took front turn signalbulbs out (disconncted them), the results were crazy.
At the rear . . . .
turnsignal switched to left . . . center trunk brake lights flash on and off.
turnsignal switched toright . . . center trunk brake lights flash on and off.
turn on lights, no tail lights work at all.
press foot on brake pedal . . . center trunk brake light works, nothing else.
Jrailer I hope you're a genius - coz it has me stumped.
I feel pretty stupid right now!
Old Oct 13, 2008 | 09:32 PM
  #7
Jrailer's Avatar
it still sounds like you have the wrong type of bulb in it somewhere
a single eliment bulb in where a duel one should be
Old Oct 19, 2008 | 05:53 PM
  #8
jtvw_2000's Avatar
so you know your not alone I've got it too 98 cabrio. everything works great till I turn on my headlights, my turn signals and hit my brakes then it all breaks loose! I've tried everything the dealer says it might be the tailight assembly itself we'll see!
Old Jun 28, 2009 | 10:26 AM
  #9
deadcabby's Avatar
Has this problem been resolved? my car just started doing this and I have no idea where to start looking for a problem.
Old Aug 1, 2011 | 02:10 PM
  #10
notafixitguy's Avatar
At the rear . . . .
gfeehan, did you ever find out what the problem was because my 95 Golf just started having the EXACT same symptoms last night. I would appreciate whatever knowledge you gained. Thanks
woody1
Feb 5, 2010 07:29 AM
samahmed2002
Jan 24, 2009 10:22 AM
gearhead6
Oct 16, 2008 07:59 PM
pdroper
Apr 4, 2008 08:29 PM
wizard5
Sep 4, 2007 09:14 PM
